I have a 1991 3FE I am replacing an engine in. I used a tip I found on this site and apparently bent my flywheel trying to remove my harmonic balancer bolt/nut with a breaker bar while the engine was out of the vehicle.. I used an impact socket wedged in it via the inspection cover to keep the engine from rotating. Now the flywheel is bent at one of the large holes. Is there any way to repair this? What negatives might I experience if I ran it as-is? As a follow-up question, how do I prevent the motor from rotating while I tighten the balancer fastener to the requested 253 ft. lbs. without risking further damage to the flywheel? Thanks for any help.
