My guess is that you have a bearing and/or pulley problem. The most common is the idler pulley below the alternator, if the bearing goes bad it can lockup and take out the belts. Also look carefully at all of the pulleys, if any are bent, have gouges, etc in the area where the belts touch it will ruin belts.
Gates are good belts and run fine on the 80. Mine are Green Stripe, have been on for 2 years and ~30K miles. Had them off before Cruise Moab, replacing the alternator bearings, they looked great, nice wear pattern, so put them back on. Due to the cogged inside profile and the flat idler pulley, they make more noise than the OEM, but that is the only issue.
There is little reason to run after market belts, good quality ones are about the same money as OEM from Dan. But if you ruin/break belts and need them quick, it good to know that they will work. Brother Rob's rig came with Gates on it, they had ~50k miles when he replaced them with OEM.
