Belt tension
Sandy Utah area
Loud belts - too loose, or too tight? I don't have a tension gauge so im doing the best I can with feel and with direct measurements (as well as using a sonic app that seems to indicate its in the right area). It's louder when its cold, its that swisha swisha noise these are known for but louder. Squealed really loud once. New main belts, old AC belt (being replaced today). Or is it just that stupid idler below the alternator?
Remove idler pulley, see if sound changes.
Remove AC belt, see if sound changes.
Belts should be fairly tight. Quarter turn twist or LESS is probably a good guide without a tension gauge.
Could be your head gasket....
Probably the idler pulley bearing or the AC idler bearing. Remove the alternator idler and replace the AC idler bearing. Easy to replace with snap ring pliers. Buy a quality sealed replacement or you will change it again soon.
