belt discombobulation question
Marietta, GA
I have a F1.5 engine with the saginaw ps upgrade. I started getting a belt squeal above 2500 RPM. In looking at the single belt it connects the PS (driver side mount) to the alternator (drivers side mount) the WP and crank all on one belt. The PS and front of the harmonic balancer have a smaller pulley groove size, but both are not connected. If I moved the PS forward so the smaller belt sizes would line up, how do I add a tensioner. Anyone done this before?
It looks like your pump has the ability to tension the belt.
Looks to me like none of your pulleys align now ???. Ideally you want the belt to wrap 1/2 way around the P.S. pulley so that the pump gets enough belt grip, otherwise squeak city all day long, even when going straight in off road terrain.
I will post some better pictures once I get the radiator off, @Downey - Since I have owned the FJ the belts have never been directly on track, finally getting around to this part of the project.
You also have to look at the profile of the belt groove, the 2 grooves on that pulley have different belts intended, which one matches the PS pulley ? Fiddling with the alignment is sometimes a pain, washer under the engine side upper may help judging by the pic.
