Bellhousing size?
TURKEY
Hi,
What is the dimension difference (in length) between 1HZ engine/H150 gearbox bellhouse and 3B engine/H55 gearbox bellhouse?
I am planning to fabricate an adaptor plate to mate an 1HZ engine to H55 gearbox, using the 1HZ to H150 bellhousing. I want to determine the thickness of that plate. Any ideas?
I read on one thread here that the difference between a 1HD-T / H151 bellhousing VS. 3B/H55 bellhousing is about 21mm, but in my case I will use the 1HZ/H150..
Thanks
Are you aware there is a bellhousing that is available from Toyota....brand new?
31111-60230
Otherwise I'll let someone else chime in with BH measurement, I'm on the wrong side of the world from one.
Hi, yes but it is very expensive to get hold on where I live (1k USD + VAT). I am on a tight budget unfortunately..
