belleview oil?
OK, either I am lame or not pulling up the correct words for a search. Fell free to call me names or what ever floats your boat.
Now for the question. What weight oil should I use to oil up my belleview? 90w or 30w? And looking at my winch, I see two places to fill it with oil. Correct?
Thanks
Hey Wes,
It's not a big difference and you probably would never notice it, but I think they specify 8oz of oil (1/2 pint). I agree, probably the same for a Belleview.
All the 8274 take 6 oz. SAE 30 (non-detergent). My guess is the bellview would be the same.
thats right sae 30w (non- detergent) oil. fill to the fill plug just like a diff
Cool guys. What is a good nondetergent oil? Most over the counter oils are detergent.
run of the mill lawnmower SAE-30.
Be careful with that winch, I tried running one on my 40 for awhile, they are great for stuff like dragging logs around, and pulling out of mudholes, but it's real easy to get in a bad situation on steep inclines and on the rocks in general due to the manual brake. Just FYI, if you let the winch unspool fast because of tension on the cable (ie not engaging the brake fast enough) it will spread the windings out on the armature and lock up the motor...
