battery water proof
The West
I have a 6/70 fj40 that i bought and it is time it needs a better battery tie down kit. I wanted to get something that would keep it dry even when i am going through the mud and rain. I was wondering if there was a battery box out there that would fit my stock cruiser.thanx
Why do you need to keep you battery dry?
(I understand that there will be some minor wear from water, but any of the newer sealed batteries should be fine in wet conditions)
I also think batteries need cooling/ventilation. Invest in an Optima Red Top, a gel battery that will not spill acid even if you roll over. Maybe rig a spray shield. Would have to go through a hurricaine or mudbog contest to get the battery that wet.
You can buy aluminum racing boxes out of most auto supply catalogs. Not necessary.
A sheild like the 80 series have is more than enough.
Get some "battery terminal sealer"- its spray shellac, from Napa and give the installed terminals a good spray. Prevents corrosion etc.
thanx i might just get a sheild/holder plastic to keep it at least 3/4 dry. very easy for me to get mud up there
