I bought a west coast 80 in the fall. It was kept until a month ago in storage with no battery tender on it. Before I put it up in storage it was exhibiting the same symptoms as it does now. It has a 1 year old Diehard AGM battery. I jumped it when i picked it up from the storage and all seemed well until the next morning. I pulled the battery and slow charged it back to life. I load tested and checked voltage and all seemed well. This weekend I pulled the negative cable and checked for stray amps and was not seeing anything over .15 mili amps,, so that says that there are no parasitic drains that could cause trouble. I am almost positive that I might have the key light module issue( will confirm when its dark) I plan to just pull the bulb and be done with this headache of jumping my truck everywhere I go. I drive everyday 6 miles to work and back, So that might not be enough time to charge battery fromits overnight loss. My biggest concern is that if the battery loses so much voltage from that small bulb, what will happen to it when i am running my edgestar fridge?? I am concerned that my jump box wont revive the truck.
I dont have a dual system and cant afford it now. I am not sold that the west coast battery is just a warm blooded POS that did not like 5 months a being drained and temps of -5 degrees.
