Battery Trays...
DShock -
Where does your air intake run after it disappears under the second battery? I definitely want to do dual batteries, but I'm not sure about how I'd run the intake.
Shinichi,
There are two hold downs and they are specific to battery size. I have the group 34 hold down.
Marc311,
It runs through the angle support and to the original location. It is a little bit of a crimp in the intake hose, but I am happy overall. It I hadn't just bought a new hose from Toyota, I would have left it off.
Thanks,
Dan
i tried to buy one and got a refund from him as he is apparently all sold out of trays. super bummed and now looking for a suitable alternative ...
anyone installed anything else that's comparable?
FYI I got my Factory battery tray replacement last Thursday also. That and the support are available pretty cheap. I'll post it up in the for sale section.
I'm selling a new factory replacement with the support that goes to the ground wire on the inner fender. This is a passenger side unit. I didn't get time to post it yet.
if i can't have the stainless, this will work. thanks for pointing it out! just need to confirm that it will fit in the stock location as well as the secondary battery spot.
instead of starting a new thread, I will just tack this brief review of the MAF tray onto this thread.
the MAF 4+ tray is nice and well built, but requires some modification to fit on the passenger side: either the use of spacers to get it sit evenly against the passenger side radiator support or lengthening the notch in the front wall of the tray (via cutting). There is a blister on the radiator support that does not line up with the tray. MAF customer service was more than helpful with proposing solutions to this problem and was quite patient with my inquires.
Also the tray will not fit a group 27 battery, which did not even occur of me to ask MAF, when I inquired whether the tray would fit on the passenger side.
So while I like the tray and it looks like it would work perfectly on the driver's side. When and if I do a dual battery set up I will probably go with this tray, but I have mixed feelings about its use on the passenger side, primarily due to the minor fitment problem and size of tray.
The battery fitment issue is largely my fault, as I should have been more specific when I corresponded with MAF about whether the tray would fit on the passenger side.
just a my 2cent mixed review.
I have read through all these posts on dual batteries and I am confused. Maybe I can just say what I am looking for and someone might help .....
- what is the size number of cheapest deep cycle battery from (i.e. SAMS/COSTCO) that will fit in a battery box that will fit in a FJ62?
- where to order the cheapest tray for the additional battery
- a photo of someone who installed (would be helpful if there were photos of the tray being installed and not just the top :-)
THANKS!
P.S. I am adding an extra battery just to run a fan all night for sleeping in the back. (And maybe a SPDT switch to listen to music off the aux as well.) I have rewired my motor home to work this way and it works just great. I spent very little on the circuitry. Just ground one side of the aux battery to the frame. Then wire the (+) wire through a fuse or breaker and then on back to all the accessories you want to run from the aux battery. You will need to keep the aux battery charged of course. Use some 10 gauge wire to build a harness for connecting the 2 batteries to facilitate a charge. I purchased some 10 guage stranded wire, an old 40Amp DC circuit breaker from an old mainframe computer supply junk shop and a 60AMP amp meter. I connected the (+) of the AMP meter to the (+) of the AUX battery, then I connected the (-) of the AMP meter through the circuit breaker and onto the (+) of the engine battery. I flip on the circuit breaker when the engine is running and I want to charge the battery. The circuit breaker trips when I have it set on and I start the car (it should not be left on when the engine is not running anyway, otherwise the drain of accessories is on both batteries). The AMP meter shows if current is flowing toward the aux battery for either charging or actually the total drain of both charging and any accessories that might be attached to the aux battery and turned on.
