Battery tie down??
Fort Worth TX. Need a ADDRESS??
Dumb one but here it goes. The PO did not have a tie down for the battery and well I went wheeling and thank god nothing happened from all the climbs. But I need to see if someone could post a pic of where and how the battery tie down is suppose to look. I cant see anywhere to hook into that would hold the battery down. :doh:
I don't have a picture, but the battery tie down uses J hooks that go into holes at either end of the battery well.
As luck would have it, I just happen to have an extra OEM battery tie down. I was planning on using it for my second battery, but it didn't quite fit in the second battery location.
They're painfully overpriced at the dealer, but the one in my garage is free to a good home.
Want it?
(assuming it's still in the garage where I think it is)
A piece of angle iron makes a stout battery tie-down, with some j-hooks from your local auto parts store. Some drilling and painting is necessary, but the end result is cheap and strong.
-Spike
where would it bolt to is the question. I looked all around to see if I found any sturdy mouting points and didnt see any that where in the tray or body. Thats why I would like to see a pic as pointless as it sounds. anyone???
You can kind of see the orientation in this picture:
The J bolts are fairly long and attach near the bottom of the battery facing out, IIRC.
Thanks Tech_dog ;)
So it is basically a piece of angle steel with flat ends that has J hooks that run from front top corner of the battery to the rear lower corner of the battery into the tray??
Yup.
-Spike
Thanks Tech_dog ;)
Close... The J hooks don't go clear to the bottom. They go out to the sides 2/3 of the way there. You'll see a slot/hole in the fiber battery tray inboard and a hole in the steel outboard. The 2 J hooks go to these.
The inboard/outboard thing applies to both sides of the truck. These things were -built- for two battery placements.
I have a rubber stretch cord holding my battery, the PO didn't have anything securing it.... Will do the angle and J-hook deal, except with an aluminum piece for extra bling.
There are quite a few different versions of some very rugged tie down arrangements for boats that would probably adapt very nicely to an LC. If you live in a town where they have a Boaters World or West Marine Store - give them a look or try boatersworld.com and search for one. I think you will have pretty good luck with that.
tech_dog, I sent you a pm if you still have yours...
