Battery Terminals
musthave
All maps, one app!
Supporting Vendor
Florida / Colorado
Replaced my alternator last night and one of the terminals is shot. Bought one at AAP and was surprised that their selection was so small.
I'd like to have a terminal that bolted on and that had two posts with about 180 degrees of separation. I want posts that are the bolt type so that I can bolt on existing connections.
I don't want the insertable type that you use the retaining screw on, like the Stinger or Scorpion styles.
Any suggestions on what to use? I can't seem to find what I'm looking for.
Like these? Military style terminals. I got a set from Napa for around $9 each
http://m.napaonline.com/parts/PartsDetail.aspx?k=NW_728223_0063685508
I'm going to pick up the ones off of Amazon, thanks for suggestions.
FYI,
IIRC, be prepared to gently drill out the existing lug or re-lug a cable or two when hooking up the OEM connections. As well as gentle with the fusible links. I was able to drill out the lug (or lugs, can't really recall) but they are soft, the drill bit large, and the remaining material a bit scanty; would be easy to pretzel the existing lug if you don't watch it carefully.
That said, I love my military lugs.
If you have not replaced any battery cables and suspect that they are original it would not be a bad idea to do some preventive work and build all new cables and replace fuseable links. I generally open up the OEM connectors with a rat tail file rather than risk a large bit in flimsy metal.
I've been using marine style posts for years and am trying the military style, I like them fine, time will tell.
If you have not replaced any battery cables and suspect that they are original it would not be a bad idea to do some preventive work and build all new cables and replace fuseable links. SNIP
I agree. I just wasn't prepared to do that when I had mine all apart at 9pm. Parts is parts until they're, err, not. On the other hand, careful reuse bought me at least 5 years of good performance, knock on wood.
