Battery question
Opelika, AL
If I step up to the 31 group battery from Odyssey or DieHard Platinum and I'm good with stock parts or should I just get a 27f?
I don't know what future mods I'll do but like to have the best without much change under the hood. Suggestions from folks that understand battery jargon.
I did 34M platinum which rules. You could do a 31 but you would need longer J bolts and you would need to replace the hold down with a piece of angle aluminum because the width wont fit inside the indention in the bracket. Other than that it will fit in the tray no prob.
Okay, well the reason I asked was cause I did read somewhere that maybe my stock charging system wouldn't be up to snuff. I'm assuming they were talking about my alternator:confused: Until that statement I thought as long as it fit in the tray with the posts on the correct side, it would be fine.
Up to snuff for what? Are you looking for a new main or a new aux battery? Are you looking for more Amps out of the charging system because there is a solution for that too and his name in Bill (Photoman)
Naw, man. I don't want to upgrade anything. I want to leave everything exactly as it is. It's just someone stated the charging system wasn't up to snuff. I never would have thought it mattered unless he was talking about a specific application:meh:.
But my stock wiring should be fine with the group 31 or 27 right? Just for everyday use.
I still don't get what the "up to snuff" statement is supposed to suggest. If you are running all stock the way Mr. T wanted it, then what you have is totally fine and pretty much ANY battery with at least 650CCA (I think that's the recommended min) will work for you. Doesn't really matter who the manufacturer of the battery is. Now if you are going dual battery or you are adding a fridge or you have aux. lights or a huge sound system or a whole bunch of 12v peripherals THEN I could maybe see something not being "up to snuff".
If you are running everything stock...well its lasted you 14 years just fine. In my book that's pretty up to snuff.
EDIT: its actually 710CCA according to CDan:
https://forum.ih8mud.com/3485100-post2.html
I run group 31s in both trays of my lx450. I don't recall any mods. I think what you are asking about is whether the alternator will be sufficient to charge your group 31. I would say yes but it also depends what your running off the batteries.
He had mentioned that there are no mods. So I am assuming he is talking about a stock system.
You're hitting all around what I'm asking. But I can gather from what you're saying the answer to my question. As far as the up to snuff statement goes I'm saying does the group 31 DieHard platinum have too many CCA's and will fry my electrical system or are there any problems I could face with my stock wiring. I take it there is not anything to consider unless I start adding crap on.
Being more direct will get the answer you are looking for instead of making us trying to figure it out :p
Let's put it this way, if you can find a 12v battery that fits in the battery tray that is "too powerful", plenty here would line up to get it.
There are a few battery threads stating Optimas suck.:meh: Most say Lifeline, Orbital, and Odyssey are the leaders. DieHard platinum is a rebadged Odyssey for half the price.
optima has changed ownership a few times recently and quality has reportedly gone down. but it seems that heat is the primary enemy of Optima batteries. So if you live in a hot climate I'd avoid one.
