battery placement
Does the physical location of the battery in the engine compartment matter? Assuming its away from interference from engine parts etc I built a bracket and have my battery just behind my drivers side wheel. As i continue to troubleshoot my wobble problem I was curious what you guys thought. I know this is from from a racecar and dont care about weight distribution....but you never know with some of these things.
also, is there a "natural" drain on a battery? Even with no lights etc on over time does just being attached to the terminals cause a battery to drain over several weeks?
Placement shouldn't matter at all, as long as it is protected from damage - heat, shock, rubbing, shorts, etc.
Small drain is normal if you have a clock or radio. Should take many months to actually go dead.
Disconnect one battery terminal and check for a spark when you momentarily touch it.
If it doesn't make a big spark, measure the drain with an amp meter in series with cable and battery post. If the drain is more than about 100 milliamps, there may be some type of short that you can find by using procedures detailed in posts that you can find by searching for "drain".
