Battery Mounting Options
Well we finally mounted the motor to the chassis. However, we encountered some problems. First being that we had to hack the rear tubular cross member off and re mount it about four inches back. Second we had to hack the battery tray off because of the serpentine belt tenisoner hit the battery tray.
Anyone have suggestions on where to mount the battery? I'm thinking it's going to go in the tub, but haven't decided yet... I'm looking for suggestions with picutures.
I'm a little bummed because I thought the install would have gone more smoothly, but I'm learning that's not the case in all aspects of my conversion. It's always something and boy the $$ are adding up fast. With the amount I've spent I could have bought a turn key operation. In the end, I hope its all worth it.
projektdotnet said:
SBC Conversion =$Lots
Big Lift =$Quite A Lot
Your friend crapping themselves
while you get fully flexed over a bunch
of large rocks = PRICELESS
^^Great tech info there, i'd do what he says:banana:^^
I went to a local Marine Supply store and purchased a battery holder box (6.95) and made a bracket and mounted it on the fender, although i'd recommend securing it the frame..
do a search for dual batteries or battery tray and you'll get a ton of info and pics on what to do....
Sounds like you've done a conversion, but I don't know what exactly it is.
I've done the SBC, and since I have the factory shock towers, I ordered a pair of the 4+Plus left and right battery tray sets from MAF. These are incredibly tough. They are never going to rust out. I did find that my horn needs to be relocated, and the RH side running light needs about a six inch pigtail splice added. Minor issues.
http://www.man-a-fre.com/parts_accessories/4+PlusFJ40DualBatteryBoxes.htm
battery tray
I don't know if you are keeping the stock heater but if you were going to replace it then here's an Idea . I did this for my bro's truck. We used all the factory mounting holes for the heater motor and an optima of course .
Can't stress enough to get it in the engine bay if you can. There is always a way. Putting it in the tub will only take up precious space a 40 can't really afford to give up. If you've ever loaded up a 40 for an extended trip/camping expedition you will know what I'm talking about. Tub space is precious - thats why ppl put coolers and such on swing-away tyre racks. Don't take the easy option you will regret it.
HTH, Lup:)
And theres me thinking this was a good use of space :doh:
Ha ha, yours may just be the exception Matt! Looks like someone went to alot of effort to tuck them away under the seat. Nice.:cool:
Lup:)
I put two Odessy batteries under the driver seat of my FJ40 white truck. Before you decide to do that think about how far it is from starter, winch, etc.
My second battery in the Troopy is in the back and considering how much room there is in the back of that rig it still gets in the way! I shall be moving it shortly.
Lup:)
Here is a couple of pics of a box I made for the back of my cruiser, In the top half of the box I have a NHRA approved battery box which hold my optima red top battery. It is vented to the outside through the floor and is bolted down to the floor. The box also has lots of storage space and is designed so that other essentials can still be loaded into the cruiser. It maximizes the storage capibilities of my cruiser rather than limits them. The box also has a lower opening section which opens up. It has worked well for me
good luck
Brian
Shouldn't cause a problem Honk. Apart from the added expense of the extra cable), most Landrovers have their batteries under the seat
Yeah, VW bugs, Alpha rRomeo, Porshe all have models using batteries remote from the engine.
Am I seeing things or are those yellow tops sitting in a well cut through the floorboard?
Yeah, your seeing right, nice job too - the only problem is PO was in California (hot and sunny) whereas I'm in the UK (rains a lot) so the well filled with water :doh: - Two drain holes now :grinpimp:
