Battery Dead?
New to Seattle, WA
When it comes to electrical I'm a -:banana: guy.
Saturday I went to crank the truck and it was a little weak but cranked right up. Then I noticed tat all day the door open light wouldn't go off, even though all the doors were shut.
So I figured there was something wrong with something.
Now this morning (Monday) I went to crank it and it was dead. Tried to turn over but not enough juice.
I run an optima Yellow top that I put in about 3 months ago.
Whats up? What should I check?
I did a deep water crosssing last Tuesday(went righ through and wasn;t deep enoungh on the drivers side to submerge the alternator), could that have done something? It ran fine all week last week, but Saturday was wierd...and today nothing...
You will need to charge the battery somehow. After that, look into adjusting the door switches.
Disconnect the battery terminals from the truck. Put the battery on a slow charge when you get home. 2-6 Amps, 10 max. Let it charge overnight.
Is it the door open LED idiot light on the dash, or one of the overhead domes?
Could it be possible that one of the overhead dome light switches was left in the "on" position? Each has three settings. On, Off, and Door.
Next step would be to make sure that one of your door switches isnt sticking and closing the connection to keep the door open. Open the doors one at a time, and push in on the rubber covered plunger. the overhead dome lights should go off. Process of elimination would isolate it to a single switch, or rear hatch switch if its a switch.
Did you happen to notice what the voltmeter was reading while it was running? A weak alternator can cause some strange lights to come on sometimes.
Ok I tested the plungers.
The dash light stays on even when the cars is off...
Drivers Door door plunger is the culprit.
When I push the plunger manually with the doorr open the light goes off.
Wehn I shut the dor the light stays on. The plunger is not being pushed in by the door for some reason...? I put a grease rag between the door and the plunger and shut the door. THe light wen off becasue the plunger suppressed? Why would this all of a sudden happen? How should I rig something to suppress the plunger?
That little dash light drains an optima battery??
I think there is a way to adjust the plunging depth (insert funny joke here).
You might want to try to remove that switch, and give it a good cleaning.
You can also try swapping the drivers door plunger with another lesser used door. That might buy you some time until you can track down a new switch.
BTW, I just followed NaterGater's FSM download thread. It is wellllllll worth the $10.00 to get access to Toyota's library.
