Battery Cable Replacement
Salt Lake City
Hi all,
I'm replacing the battery cables (and fusible link) on my 92 FJ80 and I can't exactly figure out where both cables are routed. I believe the ground cable is bolted in under the air filter housing somewhere, and I don't have any idea where the positive battery cable is routed. If anyone could let me know where the cables go and how to get to them, that would be great. I'm guessing I have to remove the whole air filter housing even to just replace the ground cable :doh:
There are 4 positive feeds off the battery.
3 are the fusible links and the 4th is the feed to the starter motor.
All of this information and a boatload more is in the Toyota FSM.
I'm trying to find this info in the FSM - do you happen to remember what section it's in?
google "birfmark" and "EWD"
@jatree Here's the EWD if you don't have it.
Bear in mind that this ewd is for the later truck, not your 3fe rig. There will be differences.
I wasn't replying to the OP. @jatree has a '96 based off their signature line.
Thanks @chap79. I do have a 1996 and appreciate the attachment.
I think OP is probably looking for the image on page 30. While it isn't detailed enough to show exactly where each ground point attaches (which is what I'm trying to figure out), it does tell you the general area and routing of different cables. I'll do some investigating and post pictures that may help others as I'm considering the battery cable kit sold by a member here.
Btw, for the electrically limited like me, I really liked this video:
Removed battery, battery tray, and air filter housing to get to ground cable bolt. Don't mix up the vacuum lines when you out the air filter housing back. Obviously positive cable goes to starter. Quite a pain to get it there.
I too would appreciate an image of where the longer negative cable attaches on a 92. I have a 91 and I've never been able to figure it out. It's bolted to the frame for now and works, but I have an electrical gremlin and want to make sure my ground is correct before I start diagnosing.
I'm not sure how it came from the factory, but unless this one is intended to ground to the frame (and I find that unlikely due to the gauge of the cable) the bolt that seems the most logical to hook this to is the rearmost one on the A/C compressor mount:
There's also the possibility of bolting it to this spot on the same mount:
