Battery Box Mount
my 45LV Jimiwag has a PO mod'd battery box mounted to the fender, it holds a single Orbital, and it holds it OK(ish), but 2 wouldn't be a good idea IMOP
also you could do something like I did in my 82 fj40, I made the stock tray a bit biger and installed a pair of Odyssey 1200MJT's I love this set up.
thats sooooooooooooooooooooo damn sweet.......:)
Radd Cruisers said:
You could do the diesel two battery dealy, not sure but I think the factory trays are still available.
Main support from should come up from your frame and only use the fender to keep the tray from wiggling. I've got pics...at home.
I am using a manafre dual battery tray for it. The tray and mounting are waaay sturdy.
I think this will bolt to the stocker tray, but I had ripped mine out for my Chebby conversion so that I could get the tray and batteries higher up and away from the motor. I made a bracket that attaches to the shock tower, and then have another bracket that bolts to the frame, and has a post coming off that. The tray is welded to those brackets, but could have been bolted to them if you dont have a welder. Heres the tray I have:
http://www.man-a-fre.com/parts_accessories/4+PlusFJ40DualBatteryBoxes.htm
-Dustin
