Bass ackwards stinkbug removal idea
Beaverton, OR
OME Medium lift stinkbug removal idea
I currently have the 851/860 Medium OME spring combo, with a winchless ARB up front and ARB side steps. I have a lot of stinkbug (1.5" or so). Since I tow fairly light boats ( 75-125 lb tongue weight & 1550 lb max), I was thinking would it work to swap only the rear springs for the 862 low height springs? Kind of the reverse of putting heavies or J's up front. Anybody done this? I don't need a bunch of lift, just would like to sit a little more level, and maybe not look so funny when I put on the 265/75 winter snow tires.
bumpity, bumpity, hmmmm, (sound of fingers tapping on table, bored whistling, you get the picture)
this thread is worthless without pictures
http://www.cruiseroutfitters.com/tech_OME_coils.html
it looks like there is a .79" difference in height between the 860 and 862, but the 862 has a higher spring rate and a smaller bar diam.??.
there is also a .79" difference between the 850 and 851 in the front, I have the 850 /860 combo and it still has a bit of stinkbug with the extra .79 in the front.
so it seems like you might have a good compromise.
Here's a pic, not the greatest, but you get the idea.
Low height springs....................hmmmmmm.
I take it you do not do much off-roading?
My first solution is buy a bigger boat.
Second is coil spacers up front (ride stays the same)
But I think that if you are happy with everything but the unloaded rake then your solution is the best.
You could give Cristo a call? he might have a different idea?
I take it you do not do much off-roading? -Nothing that requires more than 285's mostly steep dirt boat ramps.
My first solution is buy a bigger boat. Yeah , I tried that one on the wife...
Second is coil spacers up front (ride stays the same) I'm at the limit of caster correction with the OME bushings, it wanders a bit now.
I might do that, Thanks
This has been discussed previously and you can probably find threads by searching.
Stink-bug is only a cosmetic problem. It doesn't really affect drivability. I don't think it looks good, but most people either don't care or seem to like it.
I have 851 and 862 with no heavy stuff on either end. This gives a good cosmetic level appearence with some rake. Maybe a little less rake than the stock springs when unloaded, but the 862s have kept the rear end from sagging below the front with my heaviest loads (towing a 20' boat + back filled with gear). With your front bumper you would probably find the 862s plenty tall. On my truck they gave just about exactly 1" less height than 860s. If you find that the 862s are low you can always throw a 5mm or 10mm OME packer on them later.
Since your caster is marginal, you are making a good call not to go higher in the front without more correction. The Slee 3 degree bushings and 10 or 15mm of OME packers might be an idea if you want more height for the front.
