Basic Differential Question for FZJ80
California
OK this spec has been elusive to me. Is the front and rear differential system in a cruiser WITHOUT lockers full open or limited slip? I'm trying to decide whether to lift first or lock first. Any thoughts? I'm thinking Emu and Aussie?
96 Cruiser (Green) with 128k
Full open.
In your 96 your center diff is limited slip thanks to the viscous coupler.
Some markets had Limited slip diffs as an option, like Japan.
N.A. never saw a limited slip in the 80.
Emu and Aussie (rear) - good call. Inexpensive and effective. Now hop to it!
Emu and Aussie? Is that a sitcom? Do you mean ARB and Aussie? I have that setup in Cattywampus. I also have an open F&R 96 (green). The diffs are open. Go get you an Aussie in the rear, you'll be amazed at what you can do with just the rear locked. But, be sure to upgrade your hub studs as the aussies put alot of stress on those in full-floater axles.
ARB Lifts are called Old Man Emu or OME. Is there a product for upgraded hub studs?
Gotchya. Since this thread refers nothing to lifts, I 'ssumed you were reffering to lockers, but I follow now. I've had 3 OME lifts in the past. So you are not planning on locking the front?
See marlin's website for hub studs and the like for the hi quality stuff.
I haven't heard of anyone having problems with the hub studs. They're exactly the same on a factory locked 80, why would they fail with an Aussie?
here you go (and there's more):
https://forum.ih8mud.com/40-55-series-tech/253640-ff-rear-hub-upgrade-studs.html
https://forum.ih8mud.com/40-55-series-tech/238376-sheared-floating-rear-axle-studs.html
As for factory locked versus Aussie. it makes sense cause the Aussie will not fail, other things such, oh, say THE AXLE SHAFT will explode before the aussie will. Factory lockers will definitley explode as per alot of people here on the board have found out. if you wanna see an axle shaft explosion, but the aussie was good, then peep my thread:
https://forum.ih8mud.com/80-series-tech/187918-snapped-axle-shaft-semi-float-91-a.html
I'm sure an aussie will fail, but almost everything else will go before it. And the weakest link in a full-float axle with an auto locker in it is definitely the tiny little hub stubs, they're cheap, upgrade them.
edit: people can hate all they want on a semi-flaot, but i could guarantee you that if I had a full flaot in the situation that I exploded my semi flaot axle shaft, I would not have gotten as far as I did, the studs would have sheared long before. Now, as for getting the broken-beast out of the trail system, full-flaot is the way to go.
