Basic 3800 conversion details wanted.
Hello.. I am seeking basic information about the possibility of running a 3.8 6cyl buick/gm motor in place of an F motor in an early '60's fj. I've been running a variety of searches but can't seem to find concise answers... I know I run the risk of a variety of snarky responses from some of you who seemingly can't help yourselves, but I'd really like to know the available options for a basic 3800 swap into my rig. I'd prefer a manual trans, but doesn't have to be my original 3spd.... auto trans might be ok.. want to maintain 4x4..
Thanks to those who can offer assistance in rounding up the info so I can make an informed choice.
I don't think you're finding answers because it's just not a common swap.
I guess it would depend on which 231/3.8/3800 you plan on using. There are lots of versions that were not at all suited for a cruiser sized vehicle. As such There will have to be a lot of custom parts
anything is possible with enough money and time, but there are easier options with better engines. That's why there is no info out there.
. The 4.3, for instance, will have many more available options as it has the same bellhousing as the Chevy small block. It can be bolted to dozens of manuals and autos. It has a lot of variations from carbed to vortec. It has a lot of aftermarket support. It has good low end torque and a good reputation for a reasonably long life.
That doesn't mean you can't do it. Be a pioneer, but don't expect a lot of guidance. Not because we're snarky or an unhelpful bunch, but because few of us have any interest in doing something harder for less of a result.
taking that much weight off the front of an fj40 is bad off road... SBC lightens it about 200lbs, can be overcome with a winch/ bumper, 3800 is going to be about 150lbs lighter than that. and down on torque..
most of the 3800's use a 60 degree v6 bellhousing, like the 2.8 chevy, no one I know makes an adapter to go to a toyota trans for this motor,
cheepest and best option is another f motor, later 2f's out of fj60's can be had reasonable in good condition,
I you really want to do a swap take a look at the 4.8 ls chevys most wrecking yards have several and going rate is 5-800 with everything.. more hp and better fuel economy,
The 4.3 will have many more available options as it has the same bellhousing as the Chevy small block. It can be bolted to dozens of manuals and autos. It has a lot of variations from carbed to vortec.
To turbonium...
Thanks for the first couple responses... What led me to think about the 3.8 is it's (arguable) longevity and good mileage when regularly placed in cars like the buicks, that have heavier curb weights than fj40/45's right? Maybe I'm wrong here, but it seems that none of those vortecs (which I really like), small or big, could offer the types of mileage that the stock 3.8 consistently seem to throw out there. What I seek is a reliable rig for puttering around in the foothills and preferably getting the best mileage possible doing so, while still driving this old truck. I don't need huge power, but would like to approach highway speeds. I'm looking for a simple conversion with as little modification as possible. I know this site and many of it's regulars are an amazing resource and many great folks are in this community, even some of the snarky ones.
The 3800 in the later model Buicks were all front wheel drive. Finding a suitable rear wheel drive trans will be tough. Everything including the motor mounts, exhaust, cooling system, and wiring harness will have to be custom. The ECM will have to be reflashed and I think that would have to be completely custom too. I just don't think somebody will have a ECM flash designed for that combo.
They got decent mileage with overdrive transmissions in relatively aerodynamic cars that are not really heavier than a cruiser. I don't think it will push a 2 ton brick with a 1:1 top gear and 4:11 gears well.
The 3.8 in the t-type and grand nat would have rear wheel drive options and with a turbo would have some torque. The non turbo 3.8l were rated for 90-130 hp. They used the 200r4. Not a great trans and never, to my knowledge, made in a 4wd configuration.
Hi all,
Unfortunately, it is the aerodynamics, or lack thereof, and weight of the 40/45 Series that kills fuel mileage. It really does not matter which engine is in the rig, it is hard to get much over 15 mpg highway (the B/3B I-4 diesels get in the high teens.)
The "bent Buick" V-6 was a popular swap for flat fenders, but a FJ40 weighs more.
Regards,
Alan
231 Buick V6
MuddyR, if your stuck on the Buick V6, stay away from the Jeep V6's, they were only a 225 with poor performance. When GM bought the V6 back from Jeep they increased the cubes and h.p.. Get a rear wheel drive engine, but avoid the odd fire, get an even fire. I'd install a GM 700R4 auto tranny behind the 231 just to get the overdrive gear. Adaption for 700R4 to your 3 speed transfer case is available from AA. I have one more transfer case motor mount left, but I think you'll have to make your own 231-to-FJ front motor mounts??? Most of the info in my Chevota instruction manual will still apply to the 231, carb or throttle body.
Not sure the Buick is the best engine for a truck as heavy as the 40 but some more info for you.
The stock Jeep setup from the late 60s used a 225 cid odd fire engine with a 50 pound flywheel. That heavy beast provided some dampening of the odd fire as well as rotational momentum for more effective torque. The later even fires from Buick used lighter flywheels. Some people have rebalanced the older flywheel for the even fire engine to retain that extra effective torque. Since the Buick V6s were all over square, they don't make a ton of torque without help.
Most of the even fire RWD Buick V6s were 231 cid (3.8 liter), including the turbocharged engines in the mid/late 80s. Buick did make a slightly larger version from 81-84, though. It was 252 cid (4.1 liters) and is the same externally as the 231, it just has a bigger bore.
The transition from odd fire 231 to even fire 231 was mid year 1975, so you want an engine 1976 or newer, ideally.
For motor mounts, Novak sells a weld in set for Jeeps that should work fine. http://www.novak-adapt.com/catalog/engine_mounts/mmx-nb1.htm AA sells a set, too. http://www.advanceadapters.com/products/713003--buick-231-amp-38l-v6-weld-in-engine-mount-kit/
Any transmission that will bolt to a BOP engine will bolt to a Buick V6. So you have your choice of autos and manuals. AA sells bellhousings to bolt several transmissions directly to any BOP motor. In the Jeep world the popular manual transmission would be the SM420 and the T18. The popular autos would the the Th350, TH400 (stock setup in Jeepster commando), and the TH700r4.
My CJ2A has a 4.1 liter Buick V6. I built he truck with a T18 (6.32:1 1st), extra low transfer case gears (3.15:1) and 4.27:1 axle gears to give enough torque multiplication so it would work well off road. It also helps that a CJ2A weighs a bit less than an FJ40.
WHAT!!!???!!!???
GM never made Jeeps.
I could be wrong but I/m not aware of GM making any engines for MOPAR products. Jeep is a MOPAR product.
Jeeps used a straight 6 cylinder engine that was a 4.0. It was bulletproof. It could also easily be rebuilt to be bored and stroked to a 5.0 monster. The engine was dependable and so mass produced that good low mileage ones can still be found.
That being said, I've never heard of a Jeep straight six to FJ swap.
The Dodge/Chrysler V6 is what they then swapped to a few years ago (maybe a decade?) I also have never heard of a Jeep V6 or Dodge V6 to FJ swap.
Best,
T
WHAT!!!???!!!???
You're wrong.
During the Kaiser Jeep era, which ended when AMC bought Jeep corporation in 1971, you could get a BUICK 350 V8 in a full sized Jeep from the factory. Also, in the early 80's, AMC bought 2.5 liter Pontiac Iron Duke 4 cylinders from GM for the CJ5 and CJ7. They replaced it with the homegrown 2.51 liter engine in like 1983.
And lastly, Buick developed the 198 cid and then 225 odd fire V6 in the early 60s. The decided they didn't need it during the horsepower wars later in the decade and sold the engine and its tooling to Kaiser Jeep Corporation. They were used in the CJ-5, CJ-6 and Jeepster Commando until the AMC takeover. Not long after that AMC sold the engine and tooling back to Buick. They didn't want it as they started putting their own 232 cid and 258 cid inline sixes as well as their small block V8s in Jeeps in 1972. Those sixes are the predecessors to the 4.0L engine you mention.
Chrysler didn't buy out AMC and gain control of the Jeep nameplate until 1986.
Thanks, I was just about to do that, you beat me to it...
Just for the info, the 3800 isn't the same as the 231 bucks,
if you do the wiki on the 3800 they are a great motors the later ones even had ballance shafts and made the wards 10 best engines list... The only rear wheel drive version was in the camaro, and even it had the 60 degree belhousing pattern.
Yep, any 3800, 3300, 3.0L based on the basic Buick design 1988 or later is 60 degree bell pattern. Same for any 3.0L from earlier in the 80s. You want something from a RWD vehicle made between 1976 and 1987.
Back from the dead, there is a way to mate the 3800 to a r150, involves a dakota 2.5 96-99 belhousing and a ax15 input shaft as info if someone is searching, also the 2.5 jeep/dodge with a t5 bellhousing can be moded for most old school 4 speeds...
3800 swap is doable.. cheep motors in every wrecking yard cheep....
