Baselining the drivetrain??
Los Angeles, CA
So, I finished the axle seals last week, and it seems better. I am still getting some strange noises from the drive train.
I have replaced the parking brake assemblies, front and rear brakes (pads and rotors).
My next steps were going to be replace fluids from rear diff and transfer case.
The noises I am getting are strange clunking and various times, sometime slowing down, or reversing.
I hear the U-Joints are a common issue as well, anything else I should replace?
Clunks are common...but can be worked out over time.
Good idea to change all fluids.
Now if you want to check the U-joints: Look for slack while working the drive shafts, I find a nice level spot, throw out some blocking on either side of your wheels but make sure you can still get the unit to move back and forth.
If you are alone use your foot to push on any tire while using your hand and eyes to verify whether your joints are good or bad.
Do this before adding grease and after.
