Baseline 100 Series: Comprehensive List/Questions/Reccos
Newport, RI
Putting a Comprehensive 100 Baseline List together after searching and searching and searching. I just needed a good list in one place to get started. Figured I'd share it.
Recently purchased a 1999 Toyota Landcruiser, 129K miles, timing belt replaced and water pump was serviced before purchase. Suspension is stock and pretty tired. Don’t know any more than that. Going to Toyota to get service history, if they have it.
I’m going to start getting my hands dirty, while also going to a reputable local mechanic (not an LC specialist, unfortunately. Nothing near me in RI).
I'm a new LC owner. I started by posting here, and got pointed in the right direction. Thanks to those who helped. I was told to “baseline” my LC. No knowing what the LC baseline was, I researched. I reviewed the FAQ, Slee Off-Road 100 Guide for Newbies, and word searched “baseline” here. Very informative, but no 100 complete list.
My personal processes to start baseline:
1. Fluid Film the entire undercarriage (pretty important in RI, the LC came from CA is is super clean underneath)
2. Use baseline list to self Inspect what I can. Perform baselines within my capability
2. Bring to local mechanic and have them inspect the rest, while performing the “baselines” I can’t perform myself
3. Install new suspension…1-1.5” suspension lift…any recommendations on brands? Mix and match brands? Best results?
4. Apply Fluid Film any new parts underneath
Yes, everyone’s 100 series LC is different (present condition, setup, and usage) and everyone has different opinions and desires on materials (type/brand/etc.), maintenance, and scheduling. I am by no means an expert on LCs, but have some mechanical experience and have a bit of OCD!
SO, I AM NOW LOOKING FOR INPUT ON WHAT BRAND PRODUCTS I SHOULD USE, WHAT BASELINES I DEFINITELY "SHOULD" PERFORM (at my mileage), AND RECOMMENDATIONS ON THOSE TO HOLD OFF ON. ALSO, WHAT AM I MISSING?
YOUR RECOMMENDATIONS? (Especially on a nice riding and handling suspension lift set up)
I started by making this list below. Some are checks, some are definitely on the "to do" list. I only filled in answers on a few items, but I would be interested in people input.
Baseline:
Start by reviewing the 100-120,000 mile Scheduled Maintenance Guides: http://smg.toyotapartsandservice.com/guides.php
Fluids
Motor Oil : Synthetic, Brand? Weight? Cold winters, mild summers in RI.
Oil Filter: Toyota OEM
Differential Oil: SAE 80W-90 hypoid gear oil GL-5, Brand?
Transfer Case Oil: Mobile 1 LS Gear Oil GL-5 75W-90
Transmission Oil:
Power Steering Fluid:
Coolant Flush:
Brake Fluid Replacement:
Grease Knuckles:
Grease Zerks:
Engine and Compartment
Spark Plugs:
Spark plug wires:
Timing belt idlers:
Timing belt tensioner:
Cam seals: (Wait until higher mileage?)
Crank front seal: (Wait until higher mileage?)
Oil Cooler hose: OEM
Fan clutch: OEM
Check Accelerator position and throttle position sensors
Clean Throttle Body
Throttle Body Gasket: OEM
Coolant hoses: OEM
Vacuum hoses: OEM
Thermostat & Gasket: OEM
Radiator hoses: OEM
Starter contacts replacement and clean plunger:OEM
Heater Hose Tees and Hoses: OEM
Fan bracket:OEM
Air Filter: OEM
Cabin Filter: OEM
A/C Coolant Replacement:
A/C Evaporator Cleaning: Frigi Cleaner
Electrical
New Battery:
Headlight bulbs:
Suspension and Drivetrain
Rear Coil Springs:
Torsion Bars:
Shocks:
Diff Drop Kit:
E-lock Actuator Guard:
CV Joints and Boots: OEM
Wheel bearing replacement:
Rotors:
Brake Pads:
Probable Parts Resources
Local Toyota Dealership
Slee Off-Road
Cruiser Outfitters
Metaltech 4x4
Beno
CruiserDan
Many fluids are really personal preference. Not trying to make you work harder, but you could probably fill in the chart yourself after doing some searching.
For any of the items above, type the following into Google and you'll find lots of threads on what Mud members prefer:
<insert keywords/topic here> 100-series site:ih8mud.com
Example: coolant flush 100-series site:ih8mud.com​
You'll get results similar to that in the image below.
Toyota Red is my personal preference for coolant. YMMV.
Great topic for a thread though - love to see it in the FAQ!
