For the drag link (relay rod in the FSM) you can straighten it and sleeve it with a tube. Once it's bent it's weakened and will be more likely to bend again. Some people prefer to replace the relay rod as they argue that it acts like a fuse. If something in your steering is going to get damaged, the relay rod is the most likely spot which will prevent damage to your $2,000+ steering box.
Personally, if I ever bend mine, I'll sleeve it and call it good.
For the sector shaft (called the cross shaft in the FSM) you can rebuild your power steering box and replace the cross shaft with the newer style ones. The newer ones supersedes the old one. In order to use the new sector shaft, you also need a new pitman arm.
The old sector shaft's diameter narrows where the splines are, making it relatively small and weak. In order to address the problem with the sector shaft twisting, (I'm guessing) Mr. T enlarged the spline area making it much stronger and more resistant to twisting. Since the spline section is longer, it will no longer fit the old pitman arm meaning you need to replace both.
Technically, Mr. T states that you need to replace the entire box with the new box (over $2k) along with the pitman arm. Cdan figured out that you can simply replace the sector shaft (cross shaft) with the new one, and it works perfectly.
It's a fairly spendy upgrade (around $500 for the parts, IIRC), but worth it IMHO. There's been reports of people snapping the sector shaft completely off, after it gets twisted it will become weakened and a hard impact could snap it. Once that happens, you have zero control over the vehicle.
I would not do the upgrade unless your sector shaft is twisted already due to the cost, but if your splines are twisted I would highly recommend it.
