Ball joint wore out?
Vidor, TX DIXIE
New guy here. Picked up a 67 FJ40 the other day. I knew when I was buyin it that the tire was leaning into the fender well a little. I wish I had a picture but i guess bare with me on the description. When i lifted the front end off the ground, the tire straightened up and I am able to push the top of the tire into the fender well. Does this sound like a busted joint? Also, what procedure to getting into it and replacing it? My friend said I may have to press something.
There are no ball joints, but a tapered bearing top and bottom. Sounds like you have serious bearing issues.
Check torque on the bearing cap and steering arm nuts, however, I think you are long overdue for a knuckle job.
trunion/knuckle bearings...basically, if those bearings are that bad, it's time to rebuild the whole front end. Kits are $100ish, check out http://www.marlincrawler.com for one of many sources.
see the tech links under "drivetrain/axle" tech for instructions....I'm doing mine on Tues or Wed too, and will be doing a complete photo-job of it....
The guy I bought it from said bad bearing, he was an old redneck that thought it was a jeep so I wasnt gonna take his word for it. Some of my knowledgeable friends(with jeeps not yota) have said bad joint. Are there any links to refer to for pics of bad bearings, etc. and what the should look like?
check the tech links, Morgan's writeup has lots of pictures.
If you can wait a few days, I'll have a pile up as well....
