2001 LX 470. It's had a click in the front drive line for a long time. It sounds like a cv joint click to me - but I could be wrong. It is in time with the rotation of the wheels. It's not real loud, but is pretty substantial - I can almost feel it in the floor board. Sounds like the front left side. Somewhat intermittent. Doesn't do it at high speeds. Most noticable under a load from a dead start. Up a hill and turning right is worse. Somewhat worse when cold.
One of the boots on the front driver axle was leaking, so I thought it was a cv joint going bad - replaced the axle, but it didn't fix the problem.
A good mechanic helped me with it - experienced 4wd guy. After replacing the axle, he thought it was the transfer case - had it apart twice - but found nothing. Finally he gave up.
I have since noticed that the noise will go away if I put it in park, and lower the height with the auto height adjustment switch. But, as I drive, it automatically raises and then the click comes back.
Is it possible that the height adjustment is causing the truck to ride too high, and putting the axle at a funny angle, causing the cv joint to click? That's sort of my theory at the moment - but just a guess.
I would love to have opinions about that or any other ideas or suggestions. I really want to get this resolved, whatever it is.
Thanks for your help.
