Bad Vibrations, maybe from exhaust?
Kennett Square, PA
Website
cruisin4parts.com
I've been getting some bad vibrations lately when I hit like 40+. I went on the high way, and it seemed to have stopped when I hit 65.
When I hit the gas pedal, it'll vibrate, everything will shake. Stuff on my center console sometimes vibrates
If I just cruise, no vibes at all.
I don't know if this helps, but if I put it into neutral at a time when I'm normally vibrating (doing 40+ mph) and rev the engine, no vibrations.
So, I've been convincing myself that its my fault exhaust system. And I recently moved the muffler over from the driveshaft where it was hitting. But, in turn, the tailpipe now rubs up against the frame in the back and is almost dangerously close the tire.
I believe the vibrations got worse when I moved over the muffler, but then again, that was almost the same day I went off roading.
I can snap a couple photos of the pipes if you like.
Its not my u-joints, right?:crybaby:
I'm thinking this may be what us with my '92. No vibrations though, just a tapping noise that is tied to the driveshaft rpms. I.E- Slower as I slow down, and vice versa. You ever reach a conclusion on this Red Beard?
PookieBear,
In this case it was my U-Joint. Replaced the fronts and it went away. When your center console starts shaking you can bet it its your front u-joints. Now later on I got something you're describing above, a speed orientated tapping. My 92's Tailpipe broke its mount, and that was really the only thing holding my muffler in place. My muffler would clang up against my driveshaft every morning, hated it. I ended up replacing my entire exhaust system with a custom welded up exhaust, big help. No more scratching, tapping, clanging.
My driveshaft, when it gets hit, normally sounds like a bell. A high ding. Let me know how it turns out.
PookieBear,
I get a vibration when I have my foot on the brake but while sitting at a red light. Comes from the right passenger side. If I put it in neutral it goes away... any thoughts?
While driving it sometimes but not always rattles.
Mine does that too, found the the front bumper ends are missing the bolts that hold them in place and were vibrating up on the fender.
I need to fix it soon, it bugs me:bang:
Daisy
