bad vibes
Sandy Utah area
I've got a case of the grrrs mixed in with some bad vibes. Its a wub wub wub sound like an out of balance tire or bearing. I recently replaced the spindle and bearings on the PS front that I thought was the issue...it didn't seem to fix it. vibration happens at highway speeds and seems speed related. Sometimes when I brake hard the wheel wobbles like death wobble. I've replaced the drag link ends and the rest of the link ends look tight and there is no obvious play anywhere I can see. Drivelines are rebuilt and balanced recently. Tires were rotated and balanced recently. Not sure where to look next. Any suggestions?
DS? Calipers? Factory rubber bushings?
Loose or bad steering stabilizer? Is there any pulsing in the brake pedal when you use it?
I just finished up mine. Mine developed very quickly - Driveline vibes and wheel wobble. Infrequent grr...grr...grrr.
How: Replaced all u-joints (only front were bad - (vibes gone through wheel), replaced panhard X2 and swaybar X2 & the rear upper links (didnt help but definitely feels tighter in turns). Replaced TRE with (555) all of them. Only PS relay end was bad. Now it drives pretty good but when I hit 60+ it wanted to vibrate itself to death. Bought new tires in Colorado. Smoothed out the 60+ (so i could keep up on interstate but also dropped 5mpg while @80mph) but left with wobble at 40-55 (where I always drive). DS axle seal went out. Re-did both sides and heavily greased the inside of the spindles. Drives like a dream now.
Update: Checked all the linkages last night at it all seems tight, there is about 5-10 degrees play in the steering box but the arms, links, dampers and such look and feel solid. The control arms have OME poly castor correction bushings that have never been a problem. Rotors are just over a year old and were brake without pulsing at slow speeds. Front and rear driveshafts were professionally rebuilt less than 2 years ago with new u-joints and properly balanced (still have the issue with rear DS out, will check front soon) Sway bar is using a disconnect but Im not thinking thats even remotely an issue based on the symptoms. Could be gear related, could be t-case related. Who knows. Braking hard at freeway speeds produces pronounced wheel shake.
