Bad Spindles
The spindles on my 77' 40 are worn about .008". I have had a couple of good mechanics recommend speedi-sleeves, rather than buying new spindles. I work in a machine shop and am able to grind the shafts to within .0001" to achieve a good press fit. Is this a good idea in a 4 WD application? Whada yall think?
Thanks
Define "spindles". What part(s) are you talking about?
If you are thinking of putting it on the part where the hub seal rides, I'd do it, but don't they have a speedi sleeve that doesn't need machining? There is enough meat there. If you look for them, spindles can be bought on eBay reasonably:
spindle pair auction
single spindle
Dave
spindles
It's the smaller dia. where the wheel bearings slide on. There is play between the bearing race and the shaft. btw I'll check out e-bay. Thanks
Sleeving it should be fine. The down side is that sleeves aren't that cheap ($25 each around here) and you may have to turn/grind twice: Once to fit the ID of the sleeve to the OD of the spindle and finish grind the OD of the sleeve after installation.
Save your time...get a replacement part, and be done with it....
Seems like a lot of screwin' around to me....and it is only your spindle...but hey, what do I know. ;)
Good luck!
-Steve
Pin_Head said:
I don't know whether '79-85 mini truck spindles interchange with the early year fine spine birf cruiser spindles, but if so, they should be easy to come by.
All disc brake LC and mini solid axle spindles are the same......80's and non US xcluded.....cause I don't know about them....
Butch
dont even bother trying to work on it to install speedi sleeves. you could bid on the set that beanz2 posted from ebay. 9/'75 and newer disc brake cruisers,(FJ55/40/60/62) all have the same spindle as the toyota mini-truck thats a popular donor for the disc conversion, so finding a spindle should be much cheaper, safer and easier than reworking the bearing surface.
Boberino said:
I'll shop around before I commit to speedi-sleeves. :beer:
