Bad Shunto
Sandy Utah area
So I've got bad shunt, and it seems to have come on rather suddenly. how bad? It feels like it hits twice on shifts. in addition there is a sharp metallic *PING* coming from the front diff. Also my front 3rd member gasket is torn and I'm leaking (silver dollar sized puddle). I suspect the front diff wasn't setup right when the 4.56 gears were installed. Can someone take a look at this footage I shot at 6x normal speed to see if they see anything that would indicated a bad pinion/ring setup? or something else? Also, is there a good diff shop in the Utah Valley? I've talked to Cruiser Outfitters but they are pretty backed up and didn't seem all that eager to do it. I could take it to State Radiator in Murray where I know the guys well and they do a lot of cruiser stuff, but I really want a gear specialist. I know about the Toyota man in Arizona, but I can't afford to wait for shipping to and from and being without a car that long.
I know its not really exciting and I thought I was capturing audio when I actually wasn't but the thing I'm looking at is the amount of play, and specifically the way it hits, bounces a little, and hits again. There is a little play in the slipoint, but not a ton. FYI - All ujoints are new and both driveshafts have been rebuilt with less than 20,000 miles on them.
Not sure the video is working for me. I saw it wriggle around a litle, but not spinning?
There's not a lot of clearance, to be sure. Was it OK at all after the gear change? Did you make any mods/adjustments to the suspension since then? Finally, did you grease the slipjoint on the driveshaft or has it been untouched since the gear change?
I can imagine that the 4.56 gears may cause the axle to torque more when shifting, which might be just enough to cause contact. I would've thought that would start happening right after the gear change, though, if the reason for this. So it kind of depends on when you noticed the pinging after the 4.56s went in.
IT was okay, but loud since the gear change, and its gotten louder and sloppier since, but recently really sloppy. I grease the slipjoints and ujoints regularly (probably too regularly). Yeah, its not supposed to spin in the video, just rock back and forth. I should also say I shot the tcase and the rear, and while that all have play, the most is in the front and its the only place I can hear the ping
A little too much grease in the slipjoint will cause a range of issues, depending on how much past sufficient is in there. Might be worth backing off the zerk just to see if there's any pressure in the slip joint. You really don't want any, so if a little grease does escape, you might have found a contributing cause.
Also, I added a bit more speculation about the effect of the 4.56s to my comment since you replied, so may want to consider that also.
At least your pinion isn't leaking, which is a good sign.
hard to judge off a video, but my guess is the backlash isn't set correctly hence the slop. i can move my rear diff about 10 degrees. that's not good. i feel a clunk every time i take off from a stop. if yours does that, the backlash at least is off. there may be more off. if your gears weren't setup correctly, you could get a whine out of the gears. it's often only at certain higher speeds. i can't think of something that would cause a pinging outside of something actually being loose or not connected and getting tossed around inside the housing
SNIP
Good advice there.
I was thinking the pinging was tierod contact, but maybe I'm overestimating the amount of movement and the closeness of it and the pinion flange due to the angle of the pic? Not sure how much lift is involved in "springs and stuff" so mentioned it just in case that was a factor outside the diff itself.
Good advice there.
no the pinging is definitely in the gears (somewhere) as there is no physical contact here and I can get it to happen.
