Bad battery?
Frederick, CO
In the past when I have had batteries start to go out they would initially crank quickly then slow to a stop before getting that ticking noise. The last two times I have started the 80 after letting it sit for 8+ hours it was the opposite, the initial crank was extremely slow, then it started to speed up to a normal crank speed right before the engine fired. My ultragauge is reading normal voltage levels and once the engine has been running for a few minutes it will start like normal. Does this sound like a bad battery?
I don't think it sounds like a bad batt. But that would still be the first place I look. Can't you pull it out and have it load tested to see if it is good? But from there I would start with really simple stuff and clean and check all cables and connections from batt and starter. Don't forget the grounds. Just rule out the simple stuff first.
Not the battery.
Something starter related or the battery connection. + or -
Dying starter or bad connection somewhere.
Dying batteries don't suddenly wake up and provide more juice.
^^ starter , most likely.
I just went thru this scenario, chasing connections etc. my battery is only a year old, finally the starter gave up with similar symptoms as described.
Check + and - at battery and all wires going to starter.
Yeah this aligns with my suspensions. All of the connections on the battery side are looking great, but I haven't checked the cables all the way down to the starter yet.
