bad alternator??
could it be a relay wired into the truck somewhere to kill the headlights when the spotlights come on and the relay is stuck open?
pin 7 does not. the headlight does not come on.
the wires are the colour they should be.
According to my EWD, the only component between pin 7 of the retainer relay and the wire splice I mentioned in my post from this morning is the diode. I don't think you've got any choice but to locate it and remove it so you can test it. If it was bad, then the headlights would not come on, which is the situation you now have. With the wire color being what it should be for pin 7 of the retainer relay, it surely means it's OEM wiring. But take a look in the kick panel area and see if there are any non-Toyota looking relays that have been spliced into the harness nearby.
To get at the diode, it most likely means removing the combination meter, since the diode looks to be up behind it and to the right. (If you have an EWD, the diode is component D7 on page 24 [1997 edition].) Removing the combination meter is not as bad as it might first seem. I've had mine out a couple of times and it takes about 30 minutes. There are instructions in the FSM. The diode is most likely a small, black rectangular-shaped block with two wires going to it: one red with blue stripe and the other red with white stripe.
You can test the diode with the ohms setting on your multimeter. Hook up the two meter leads to the two terminals on the diode. When you hook the leads up one way you should get a few ohms resistance. When you reverse the leads on the diode terminals, you should get very high resistance. Anything else means the diode is bad.
Tom I have had the combi meter out before. The problem I foresee here is that I am leaving town on a road trip for a week so if it is the diode I can't fix it, because my local dealer takes a week to get anything. the other problem is I am stupifyingly busy trying to get ready to go.
would temporarily putting the jump wire back in place to bypass the diode be a bad idea? I am assuming the only thing the diode does is kill the lights?
You can install a jumper wire to get the headlights functioning again, but there's an easier way to do it than the previous jumper wire. The old jumper used to run from the headlight relay in the engine bay to a wire coming from the headlight connector on the steering column. You can accomplish the same thing right at the steering column connector. Just attach a short wire going from the black-orange wire on the steering column connector (pin #13) to the red-white wire on the steering column connector (pin #14). Do not cut the existing wires, just add the jumper. Your headlights will be in completely manual mode then; you turn the headlight switch on and off, irrespective of the ignition, to get the lights to function. By not cutting the OEM wires the "flash" mode on the headlights will still work too. You'll need to re-connect the retainer relay for the parking/tail lights to work. Then when you're not so busy you can check out the diode. I suspect a replacement diode doesn't cost much, maybe $5 (total guess on my part). So one approach is just to order the diode so when you pull the combination meter you can just replace the suspect part and not have your dash apart while the dealer does a special order.
Let me know when you're ready to rig up new daytime running lights and we'll come up with something that works better than your old set up. Maybe someone here on mud has a good solution for this.
