ok the drl was accomplished by jumping directly from a wire (cut) going into the headlight relay in the engine bay fuse box to a black wire with an orange stripe (cut) that went into one of the two steering column plugs. I have cut out the jumper and reconnected at both ends to the original wires so hopefully that will eliminate some of the funny business. hopefully i don't get a ticket for having no DRLs.
According to my EWD, the black-orange wire at the steering column connects to the headlight retainer relay. Depending on what terminal the extra wire connected to at the headlight relay, that could have effectively by-passed the retainer relay and caused your headlights to be live even when the ignition was off. Getting rid of the DRL and restoring the wiring to original form is certainly the right thing to do at this stage. At a minimum it will help us diagnose your problems. With the extra wire gone, do your headlights now behave like an OEM truck? Could there be other modifications to the wiring in your truck still present? If so, tell me about them.
Overall, I'm thinking this has got to be a wiring harness issue. I can't otherwise see any way for all the symptoms to be connected. I know you're in Canada and it's likely cold, but could you try pulling out the heater relay and driving for a while without it. It's in relay block #1, left kick panel. There should be no way the heater fan can come on then and I'd like to know if any of the other symptoms change when the relay is removed. The relay is certainly not the root cause of your problems, but removing it and seeing what symptoms change may provide additional clues.
Lastly, while you're under the steering column and inside the kick panel, look around for any signs that the harness as been rubbing against metal and perhaps has become frayed and bare wires exposed.
