backspacing ?
West Georgia
i know this has undoubtably been discussed many times, and i did a search on it and didn't come up with any kind of conclusive answer.....i am getting ready to order 38x16.5x12.5" swamper tires and 15in x 10 wide trailready rims with 3.5 backspacing and i want to make sure before i order those wheels that that backspacing will be okay? i have stock axles, disk brakes, soa, marlin hi-steer arms and fj80 tie-rod ends. if anyone can help me out i would really appreciate it!
Im pretty sure you need 3.5 back spacing or you will need spacers
...but with 38's you want spacers to keep the tires off the springs up front anyway. Are you getting beadlocks? If so I think 8" rims would be better. I'm running 38.5x14.5x15's on 15x8, 3.5" BS rock crawler's with Long's beadlock's and had to run spacers.
yes, i'm getting beadlocks, but i'm clueless as to what to get as far as brand, size etc., what kind of wheels do you have just regular steel wagon wheels? are the spacers strong enough? anyone ever had any failures?
So.......
Did you ever get those big meats streetable? :)
aw
I'm not expert but have been researching and asking bunches of questions on the matter. Size 15x7 or 15x8 with a 12" or 14.5" wide tire. Don't get a reverse cut rim for beadlocks. Reverse cuts have the long bead which is normally on the back, reversed to the front, thus making the beadlock rings need to go on inside of the rim to be effective. I went with a 3.5" BS and 1.5" aluminum spacers (torque and re-torque often!!! Ask me how I know :mad: ). I went with a 15" rim cuz they are cheaper then 16.5's and so are the tires....but that's just me. As far as strength...Woody and I'm sure some others are running them and he abuses his junk way more then I do. Rascal on here has a set of Long's also and really likes them.
Alec - Fawk NO .... but I'm gaining on it :D Got 'em so I can drive into town on the back roads, still a little freaky. Flip'n the front springs, rebuilding the knuckles and working on the caster angle now. Still look'n for some 37" radials for highway. :grinpimp:
I run 39.5 IROK's in 17x9 Allied beadlocks with 3.5" backspacing and 1.5" spacers. Zero complaints.
I ran 38.5 SX's on 15x10 Allied beadlocks with 2" backspacing, zero complaints.
IMO, for a 37+ tire, you want 2.5" max backspacing to allow some turning clearance and room for extreme articulation without hitting the frame in the rear and fenders in the front (and even with my 2" effective spacing, things hit a lot!)
mookie said:
okay, so now i'm thinking 38x12.5x15" tires on 15x8 wheels, could i get some made with 2" backspacing? or would that be too weak? thanks for all the good info!
When I was doing some searching for BSed rims, Summit will do 2" BS rims for you and has a good turn around rate. I would call them up and see if they still do that.
Travis
I bought the 2" backspaced steel wheels. Haven't had any trouble after 1 year. Maybe it's just in my head but it sure feels more stable with the wider stance.
troy
Stockton Wheel will build anything you want. They did 15x8, 3.5" bs, powder coated "rockcrawlers" for me for reasonable money. You can call and talk to the owner. I had a very good transaction with them.
Stockton Wheel
