Backspacing
Hi guys, time to upgrade the yoda. I’ve been running 33” tires in stock suspension for a few years now. Just installed OME heavies. Was given some almost new 35x12.5x18 Toyo Open Country M/T’s. When ordering new 18”x9” wheels, what backspacing would y’all recommend?
Like 4.5 inches
3.5-4.25 on a 9 inch wheel. If you go with a 12.5 width tire it will rub on full stuff in the rear with a 4.5. I’m running a 37 inch tire 4.5 bs rim with 3/4 spacers.
Wouldn’t 4.5” or 5” be better? If you are running 4.5”bs with a 3/4” spacer, isn’t that essentially 5 1/4” bs? Or does it not work that way?
Stay with a centered wheel... for 9" wide that is a 4.5" BS
for 35s you will need to lower your bump sops to 1.5" on all corners.
@Hitit66 sells them here on mud.
Only if you're measuring from the back edge of the wheel. Wheel width is usually measured between the bead surfaces (I.D.), BS is measured from the outside edge. The wheel rim usually adds 0.5", so an 8" centered wheel has a 4.5" backspace. 9" wide wheel has a 5" BS when measured by the wheel industry standards, and that's how a retailer or manufacturer will say it.
OK thanks
Yes, the wheels that I bought are 18x9 with 5"BS. I bought 1.25" spacers just in case I needed them
