Backfire
Port Douglas/Queensland/Australia
Hi all,i am new here,thanks for having me.
I just bought a 1976 FJ40.it runs and drives and is in decent shape for the age of the car.small oil leak on the front balljoints,and the clutch might need replacement at some stage.it does backfire under load every now and then,reading trough this forum,sounds like a common issue,i just had a mechanic friend resetting the flood levels on the carburatour,will put a new vacuumhose on tomorow and also change the coillead and check the distance on the sparks.after all that it might be the timing.any other suggestions?happy for all information.so just that you guys know,i am new to all this,got a mechanical understanding but not to deep,
Thanks
Welcome to Mud. Rig pics=faster response:). Engine pics might get us all to respond better. Start with the cheapest hunch and eliminate potential causes. There are multiple potential reasons for symptoms you cite. Share pics of front and both sides of the engine bay.
Thanks
Backfiring through the carby or the exhaust?
Backfiring through the carb usually indicates a lean condition, look for vacuum leaks, double check the ignition timing, then check carb jetting.
Backfiring through the exhaust usually indicates either a rich mixture, leaks in the exhaust manifold or headers, or badly retarded timing.
Where is the backfire coming from? The tailpipe, or the carburetor?
Thanks for this information,it backfires through the exhaust,i dont believe there is a leak in the manifold or headers,i will change today the vacuumhose and coillead,and if is just for maintance reasons.and get my mechanic to adjust the timing.the holley carb was runnng to rich,we fixed that yesterday.i keep on reading different numbers for the NKG sparks 0.31-0.39.so where should i be on that?
Cheers
Cheers
Is it still backfiring through the exhaust, after reducing the jet size(s) in the carb?
Even a tiny pinhole leak in the header can cause a backfire. Headers eventually rust out, and it always starts with pinhole leaks, in my experience.
My 1980 2F factory service manual says 0.031 inches (0.8 mm) for the spark plug gap, but that is for the later electronic distributor. Not sure if that is correct for your '76 but it would be in the ball park (on the cricket pitch?).
Got some pictures for u mate
Hi,i just went for a short testdrive after adjusting the carb,might have been just some exess fuel.just changed the coillead and vacuumhose,i will start with .039 on the sparks,testdrive it and work my way down if i have too.thanks for the help.cheers
Hi mate,so,i checked all the sparkplugs today,they have been all out,with my tools i could get not number 6 out,so i went to my mechanic,i told him what i was doing and he double checked,turnt out,the previous owner put wrong plugs into the engine.i get that changed this week,but even with straighten up plugs,the engine was running so much smoother,looks like i am on the right way.
Cheers
