Well my overheating problem with the 4runner is getting worse. Going to bring it back to the shop tomorrow and see if they can get it back sooner than 3 months this time
Well got some advice I had not even considered. Because I am just using a single vacumeline for my advance, and tee-ing it off to both ports on the dizzy, I might be pulling too much advance, and that might be the source of my overheating, and wh it cools off so quickly at idle.
need to pick up a timing light and see just what is going on with that.. GOING HOME TOMOROW!!!!!!![]()
having done it.
dont get it.Are you carb or fuel injected?
That would be carb, they didn't fuel inject the 22R until 86. He just put a weber on there not to long ago if I'm not mistaken.
Yea I need to reread all what is going on with your engine but I'm at work , so I'm really not suppose to be on the internet. By buddy has an 1985 extra cab solid axle that came fron the factory with EFI.His brother has an 1986 extra cab that is carb.
So if you needed a truck to compare yours to I can talk with him.
Does the elec. fan push or pull? You might not be able to move it.
Later,
It is an el' cheepo from Autozone. it is made to blow through the radiator, but in the instructions they showed you how to rewire it for draw through, the fan is also made to be removed and turned around in the housing so that it will bite in either direction.
I FOUND MY PROBLEM FINALLY!!!!!!
The waterpump was going bad slowly, at Idle it pushes no water at all, and at about 2500 rpm it barely pushes any either but it must have been enough to keep the engine coolish.
Going get a water pump right now I will check back with yall in about 4 hours and let you know if it worked or not.
