Just got it out again after 2 years of work. Tom woods shafts, SBC engine, new Marlin diffs, new cooling, wiring, bushings and shackles, done body work and lots of small stuff that needed done.
I mounted the battery in the back. Welded up a custom box on the passenger fender. The rear pinion has been in that position for many years without any trouble. Never had any issue whatsoever.1. Congrats.
2. Where’d you mount the battery?
3. Is that rear pinion angle safe?
I mounted the battery in the back. Welded up a custom box on the passenger fender. The rear pinion has been in that position for many years without any trouble. Never had any issue whatsoever. I run a custom Tom Woods double cardan rear shaft. Works well at highway speeds and crawling.
