Axle upgrade question
Hey guys,
Please confirm this for me or correct me if I am mistaken. If I were to get an 80 with no lockers, and wanted to lock it I think on the front I could just replace the 3rd member with no other mods. The rear is a different story though since the non-locked axle is not full float so I would need to swap in a whole FF axle with the locker in it.
Right? Or am I off my rocker? And no ARB suggestions, thank you.
Kyon
full floating or not full floating I think depends on the year of the cruiser, the early 90's were semi floating, I think in 94 or 95 they are all full floater and you can just add any locker to the existing 3rd member or find a locked one.
The front axle housing will require mods, you have to do some welding, cut/grind a notch for the actuator, and drill/tap some holes.
how about the rear?
Okay, understand the front.
is elgenb correct? Are all of the late model 80 full float in the rear? If so, will the 3rd member drop in or are there any other changes that need to be made (axle shafts)?
Thanks
The lockers change the third from a two pinion design to a four pinion design also, and I'm not sure if that required any additional clearance in the locker axle housings?
DougM
Rear swap is a :banana: :banana: job. Very simple. The front requires a new axle housing or a modification to be made to the existing. If you are OEM OCD and have to have the factory set up I would advise you to keep shopping. It is an expensive endeavor. If you just want lockers I think there are easier and less expensive ways to to go.
I did see a FOR SALE post recently listing front and rear hub to hub factory lockers for 2400.00. I think they are gone now but the seller indicated he sees them often. They will also give a buy back on the none lockers. I want to say it was Ibris.
