Hey guys, need a little help.
I have a set of 80 axles that Im putting under my fj60. I plan on using all of the 80's links and mounts, and also lift it about 6". So my questions for you guys are:
1) What should I take into account right now about link mounting. Meaning what have you guys with lifted 80s found out after lifting your 80s. Should I adjust the pinion angle, change the links, ect.
2) What coil spring would you guys recommend?
3)What are my options for a hysteer set up? or is that even needed?
4) Any other suggestions?
