Axle Spares - What Else Do I Need?
Nay
Colorado
I've picked up a set of spare front and rear axle shafts, and two spare birfs. What else do I need in order to deal with a busted rear axle, or busted front axle or birf in terms of special tools, seals, lube, etc.?
Trying to ensure I have a complete spare/repair kit for everything but the 3rd.
:cheers:
For a Quick-and-dirty trail repair (front) you will need inner and outer spindle gaskets, an inner oil seal, a lock tab washer and a drive glange gasket. I would also carry the snap rings and maybe trunion bearings and a ball-wiper set.
The rear would be an inner axle shaft seal and an axle flange gasket, unless you twist the splines on the RH shaft of a factory locker. In that case get out the torch..:lol:
54mm hub socket
12mm socket
snap ring pliers
hammer
brass drift (if you choose that method to loosen the cone washers)
flat screw driver or pliers to remove the front dust cap
Something to scrape gasket material
Molly grease for the birf
80-90 to top off the diff as required
For the rear there is a three prong tool. If you have that it makes everything a lot easier to dis-assemble to get the axles out. I think it is like $60 plus the ride from cdan. Now if you have it already "never mind"
The wrench is not required to remove the axle shaft. It's used to get at the wheel bearings and to remove the hub. all that happens after the shaft is removed.
Mine rides around with me all the time as well.
Excellent, thanks for the responses :cheers:
Will be placing a call to Dan once finances are in order. My water and sewer company pumped hundreds of gallons of raw sewage into my basement and has no decided they won't pay for it.
Lawyers before spares :eek:
Nice.
:eek:
It's been a s***ty :eek: summer.
Pun intended i'm sure (sort of another thread alltogether, but how would one prevent this problem ... are there "one-way" flapper flush valves or something to put in the main waste line out of the house?)! This thread got me thinking. Do we have/ can we make a FAQ on "down and dirty trail repairs" which will limit labor time and carrying tons and tons of parts on the trail but which will maximize safety and reliability enough to "get out and get home?" I think that would be cool. Links? or Thoughts? Thanks. :cheers:
As a newbie to the whole crawling/wheeling experience, I've been trying to figure out what I need to carry when going out. A FAQ of said nature would make my job a lot easier. :hhmm:
I'd like to see this in a FAQ for spares, and yes, you can install a backflow prevention valve. I just had the Clean Check value installed, which is owner maintainable. Huge peace of mind. Puns intended, and they go on and on :eek:
