Axle leaking all over outer wheel.....
North GA
So here we go...more gremlins. Noticed this today when I got home; axle grease splattered all over the outer wheel. Then I notice the I'm missing the piece that covers the flange....you can see the difference in both front wheels. Have I blown a seal on the drivers side or do I just need that hub to cover the flange?
Check the knuckles on inner side if they are dripping gear oil then yes your inner axle seal is worn if they just have grease on them you are probably ok on the axle seals.the grease you see may be from your wheel bearings.but worth diving into check
Knuckles look about the way they did when I bought it. Slightly weepy but not puking by any means. I've never seen it splatter like that on the outside of the wheel. Only difference in the two sides is one is missing that center cap over the flange. Thought there might be some correlation there.
What does a blown wheel bearing look like? And I'm not noticing any noises.
All you likely need to do is buy the metal cover that is missing from whichever side. There is always a bit of grease inside the spindle as it is what lubricates the brass bush at the inside end of the spindle. The grease comes from the Birfield cavity in the Knuckle. Unusual for the cap to come off but yours has.
Most likely there is nothing wrong with the wheel bearing based on these pictures.
Your wheel bearings ride on the outside surface of the spindle
To check wheel bearings jack up the wheel and grab it at 12 top and 6 bottom and see if it moves at all.
if there is any play when pulling the wheel holding it at the top and bottom then the bearing will need to be checked and adjusted or replaced.
