Axle end wear?
Folsom, CA
Opened up the knuckle today for a rebuild. I was surprised to see that the end of the long side axle has a distinct wear pattern. Both C clips where in place and functoning. The only way I can see that the axle would wear like that is the outer C clip was not holding the axle back. But, when I removed the outer C clip, it was snug in the grove on axle. :confused: So now I will be scrouging for another axle. Luckly I live very close, well 20 min, from Placerville, CA with lots of cruiser heads.
I've seen that before... From someone who could not get the axle in for some reason and took a hammer to the end of the birfield to get it in. Then when they could not get the hub to slide over becuse the threads were slightly tweaked, they took a grinder to the axle. So that is my best guess, not weak but someone with a grinder... :)
I've got axles that look just like that.....beaten by the inside of the birf bell...
take a file/hacksaw blade to it, clean it up enuf to pound into the birf, and run it (or at least keep it as a spare)...nothing wrong with that, other than being ugly....
Really? OK, if you say so. I will keep it as a spare. Still makes me wonder how it was able to beat itself against birfield.
