Axle code identification
AFAIK all uzj100 up to 02/02 are 4.3, where was this one purchased, what country. What is the vin number
Finally got the details as car was in for some work :
TOYOTA South Africa imported the vehicle
model no GF-UZJ100W-GNPGK-G,
TRANS/AXLE code A442F AO2B
and plant code A11
Thanks
I don't know the answer to your question but I can tell you my axle code is A04B which is 4.3 LSD. Usually, the 1st digit is the ring gear size, the 2nd and 3rd digit identifies the axle ratio and the 4 digit identifies whether it is (Locked, Open, LSD). So, likely, you don't have a 4.3 Do you have an LSD?
What do other 100 owners have for their axle code? (It is listed on bottom of the sticker on the drivers side door jam).
Axle code in my 2003 is AO2B but it's ratio is 3.909
I believe in my first statement about 4.3.......this is from parts specs
If the VIN number shows up I may have a better go at it.
I haven't been able to find a table that confidently translates axle codes, so I am relying on this at the moment. If anyone has a link for something a little more definitive I'd be very appreciative.
We put lockers in some time ago so have confirmed the following / A04B is:
* 4.3 ratio
* 4 pinion
* open centre / non-LSD
Hi Yspen,
GF- UZJ100W-GNPGKG:
If this is the VIN (?), then it is a very strange one.
It may help to check the Model Designation which should appear either on a plate on the firewall in the engine bay, or, on the “B” pillar (between the front and rear door). Then you should be able to see something like:
UZJ100L or UZJ100R where “L” is for left hand drive and “R” is for right hand drive. It is hard to understand what “W” means.
(If diesel, the first three letters will be different)
In your case for the 2UZ-FE gasoline V8 engine, the whole model designation should look like UZJ100L-[six letters] where all the six letters have a meaning – see attachment.
It helps to know the model descriptor and model year but otherwise look through the years shown at this FSM site -- https://lc100e.github.io/manual/ -- as identified by Moridinbg .
It is likely that a South African vehicle has a EU/UK specification.
At this link, go the menu panel on the left hand side of the page, open up the various selections for your model and year and pull down “MAJOR TECHNICAL SPECIFICATIONS”.
Look for your six-letter model designator and read down the relevant column until you find the “Chassis” section which shows details of
“Transfer Ratio H4/L4”
“Differential Gear Ratio (Front/Rear)”
“Differential Gear Size (Front/Rear) in.”
For example, my vehicle is HDJ100R-GNAEZQ -- see vehicle details below. This is the model designation, not the VIN. In my case, the code means:
HDJ – 1HD-FTE diesel
R – right hand drive
G – station wagon
N- Lift up back door
A – 5 speed auto transmission (A750F in my case)
E – VX (or Sahara in Australia)
Z – Multi-valve, turbocharger, EFI
Q – Australia
I know the specification for differentials given in the information for my vehicle are correct because I have used the VIN (not just the model designation) and checked with a local Toyota dealer who has access to Toyota Global Information System. In my case
Differential Gear Ratio (Front/Rear) 3.909/3.909
Differential Gear Size (Front/Rear) 8 inch/9.5 inch
Your vehicle will be different but you may be able to find the relevant information at the above link. A check with the Service or Parts Department at a Toyota dealer also may tell you what you need to know about your axle.
The axle designation for my vehicle is “AO2A”. The actual Axle specification details are exactly as they appear in all published information on my vehicle.
Be wary. There are various charts of axle designators on the internet but I found it hard to find exactly the right axle chart on the internet for my vehicle. My details are not consistent with some axle charts I have seen and I have concluded that I have been looking at the wrong axle charts.
Hope this helps.
Thanks for the heads-up on dates :facepalm: -- just shows that wandering around the IH8MUD Forums should not be done late at night as an attempted insomnia cure!
Cannot help with password on the secure documents -- I can't open them either. I can download using Chrome and print and highlight. If I want a section or an extract or a diagram, I "snip" it from the screen image -- but I cannot extract words or diagrams directly from the document.
