Need your input, Did the search my eyes are getting blurry,
For my 6640 with 2F 4-speed and original one piece 66/3-speedT/C . I just obtain some later Axle's 76 with disc Front and drum rear, soon to git a RDB conversion,
Question is I would like to use the larger bolt pattern later style drive lines with 11-mm bolts Vs the smaller pattern 8-mm bolts, is just a matter of changing the E-brake drum / and the front flange ? is it that EZ ? or are flanges different spline on the 76 40?
Original E-brake
Later drive-line...Input please...Dusty
For my 6640 with 2F 4-speed and original one piece 66/3-speedT/C . I just obtain some later Axle's 76 with disc Front and drum rear, soon to git a RDB conversion, Question is I would like to use the larger bolt pattern later style drive lines with 11-mm bolts Vs the smaller pattern 8-mm bolts, is just a matter of changing the E-brake drum / and the front flange ? is it that EZ ? or are flanges different spline on the 76 40?
Original E-brake
