AWD on the 80's
Seattle WA
Can a FJ-62 tranny be a direct replacement in a AWD '92 - '92 FJ80? I think they are both A440F trannys. Are there any known compatibility issues?
Thanks.
Tim
A while back I read an article where someone was trying to do a similar swap. I think you would need to use the torque converter from the 80 because 80 3FEs have a larger diameter pilot bearing than the 62 3FEs. Plus I don’t think the part time TC and the full time TC are interchangeable.
Hopefully someone can confirm this. If not, try the 3FE Yahoo group.
IIRC, the transfer case adapter plates are different between the 62 version of the A440 and the 80 version of the A440. If they were identical then someone would have made a part time 80 Series by simply swapping transfer cases by now.
