Hi guys,
With heated seats on the way as well as a reverse light and an inverter sitting around waiting and plans for more stuff in the future, I figure it's time to plan out my auxiliary electrical system. I've drawn a diagram (below), and decided what items I want connected where, and whether it should have constant power (hot) or power only when the truck is on (switched). I've already got a length of 4ga wire running from the rear passenger quarter panel up to the centre console, as well as another piece to get from there to the battery. I have been able to find the amp draw for most of the stuff. How much current is normally drawn through a 12v outlet (ARB fridge, air compressor etc?)
Heated seats 10A x2
CB 2A
Inverter 15A normal (35A surge)
Back up light 5A (=55w bulb/12V)
12v outlets ?A
Footwell/tailgate lights 1A each x4
I’ve seen the Painless fuse blocks that have constant and switched hook ups. I’ve also seen some less-than-favourable reviews of these fuse blocks and their quality. I also wonder how four 20 amp circuits are supposed to run through one 30 amp breaker. I’m no electrician, but that seems like it wouldn’t work to well. Is there a better solution out there than the Painless, either buying something or making it myself? Or is the Painless stuff ok?
Heated seats 10A x2
CB 2A
12v outlets ?A
, so I like the idea of using the Painless blocks with some ignition-switched terminals. But, I'm not sure the quality of the Painless blocks and their ability to handle 4ga, or whether I'd be better off trying to make something myself (how
