Auxiliary light mount advice
Alabama
How high should my hella euro beams be if they're mounted in the middle of arb right about winch as far as beam height? Should they be level with my high beams at 25 ft?
For lights that I may ever run while on a road, I try to have some drop to the beam. Park on level ground, about 25' from a wall (or vertical surface). Measure from the ground to the top of the light. Measure from the ground to the top of the main beam. Aim the light so the top of the beam is lower than the light. If the lights have enough stray light that a lot of it goes up (no matter how they're aimed) as is common for LED lights; then I'd consider them "trail only".
