Who makes a mounting plate for a Blue Sea set up? I know many companies make them for late models. Any thought on one I can use for my 80?
I’d like to mount one there. What do you have the fuse block secured to?
I used two maybe three pieces of aluminum bar, 1/8" x 1" wide, bent and drilled to fit the block. Probably two feet total material.I’d like to mount one there. What do you have the fuse block secured to?
Which Bluesky unit is that?
I don't understand why folks would remove their ABS.I removed my ABS module and installed a custom aluminum plate to mount my Bluesea fuse box. I have a relay box under the hood and reused my ABS pump mount for that.
