Autometer temp sensor
"the whale's vagina", CA
installing an additional guage on my truck as part of my interior rebuild. 1996 FZJ80. I am purchasing this guage:
AutoMeter Ultra-Lite Analog Gauges 4337
looks like it comes with a temp sensor that needs to be installed in the block and contact coolant. Wondering if anyone can comment on a good stock port to use for the sensor location?
Thanks,
Noah
Here you go. Adding coolant temp gauge?. Check posts number 40 and 46 for the water outlet neck where you can install the sender.
There is a flat on the lower or rad pipe or thermostat housing or outlet pipe (can't remember which) that can be drilled and tapped for 1/8" NPT. Because of my battery disconnect mount I added a 38mm tube in both radiator hoses. Both tubes were pre-machines for an 1/8" NPT fitting.
