Automatic Transmission Woes - Please Help!
Sandia Park, NM
I am still battling with my commuter car to make it useful for replacing my FJ60 (that's all the cruiser content in this message) for daily driver use. It's a 1989 Camry, 4 cylinder with an automatic transmission. I thought the car was a good deal because it only cost $100. Even though it needed a new engine I figured I could easily be into it for only ~$1,200 when I was finished with an engine from salvage, T-belt, cap, rotor.....
Man was I wrong. For the last ~3 months, I have been battling with a leaking transmission that I simply cannot seem to stop. Here's a summary:
Put motor with new parts in the car, start it up and shift in an out of gear. ATF starts dribbling out from inside the bell-housing. "Son-of-a-bi!@#"
Several weeks later, I get time to take the transmission out. I replaced the input shaft seal which is what seals the tube that's welded to the torque converter and goes into the transmission. I started it, shifted it and no leaks. I took it down the road and discover it started leaking again. But it's less than before.
Now I'm really pissed. I debate putting it up for sale and just telling the future owner it has a transmission leak that needs to be repaired.
I decide not to give up that easily. A few more weeks later, I finally admit defeat. I took the transmission out and took it to MATSCO Transmissions. He tells me the shaft on the torque converter has enough wear from the seal (after 130K miles) that it should be replace. So, the torque converter, shaft seal, pump cover gasket and the seal for a plug inside the bell housing (don't know what it's for) are all replaced. The invoice states R&R on the bushings as well. I even put in a new kickdown cable because the sheath on the old one is busted. Now I'm into this transmission for $600. There's no turning back.
So, a week ago, I get it all back together. Fire it up, no leaks - for about 5 minutes. Then it starts dripping again, about a drop every two seconds. My father drove it on Saturday to get the emissions tested and said that it leaks worse ( a stripe on the road) when you drive it.
Motherfu....! I am now into this car for pretty much market value, ~$1,800. I can't figure out why the hell the friggin' transmission won't stop leaking. The engine runs great, the AC is cold, the interior is in great shape. There's a few little cosmetic issues but it's basically the perfect commuter vehicle if it gets the expected 30+ mpg.
Does anyone out there have any idea what to do next?
My plan is to take the entire car back to MATSCO but who knows how much more money I'm going to have to spend. I'm catching a lot of grief from the wifey for how much money and time I've apparently wasted on the POS. She's even suggested I sell it and the 60 so I can have enough money for a late model, reliable car like a Civic or Corrolla (one that's not more than 10 years old). I told her she's blasphemous for even considering that I should sell my 60 if I'm not replacing it with another Toyota 4X4. If I had plenty of extra money, I would have bought the Civic or Corolla already and been saving $100/month in gas. If I'd done it a year ago, I could have spent $3,000 on a car and I would be even with my current expenses and lack of fuel savings. Plus, I wouldn't have wasted at least a week's worth of days off over the past several months. I'm not even sure how to put a value on the days off I've lost to this little car. At least it gave me an excuse to hang out with my father and do some wrenching together. I don't think I'd see him much if I didn't have a bunch of old cars that seem to always need maintenance.
- Marc
MATSCO will not stand behind their work? Did you try AAMCO?
We haven't gotten to that point of the transaction. I'm not the one doing the dealing - my father's been taking care of this stuff since he's 'retired'. MATSCO came recommended by two different people and I'm sure they will stand by the work they did but that was limited to replacing the seals, torque converter and R&R on bushings. I removed and brought the transmission to them the first time. Now I figure I'll have to pay more money since I'm taking them the whole car.
I think it depends on whether or not you told them what to do or just said you thought that was the problem and told them to "fix it"...
- Marc
Go with the wify and sell both. Then save up the money for a 4x4 down the road when you can drive it w/o griping about gas mileage :D :flipoff2:
Ha Ha. Funny guy.:flipoff2: Save money? What planet are you from? Even if I had more money, I'd still complain about gas mileage because I'm a cheap bast... I mean I'm a frugal person.
...I mean I'm a frugal person...
I'm not frugal to the point of being cheap like Marc, but now that I'm commuting to the friggin airport everyday I'm startin to pay attention to gas prices. Figured I'd buy a beater commuter but now Marc's experience has me gun shy...
... but now that I'm commuting to the friggin airport everyday I'm startin to pay attention to gas prices.
You and Beno should car pool. He already has the beater and you could ride your bike to his house in about 10 minutes. :D
-Mike-
Greg can carpool with Beno to the airport as well..
